Lil-Joe101
Dec 3, 2012 - 10:57 PM
I know this topic has been brought up numerous times but I just can't seem to find it in the stickies. Im trying to figure out what clutch I need to buy for my 3sgte swap that I've done. I'm running a 3rd Gen 3sgte with an s54 tyranny. I want to buy a brand new clutch kit. Please help me.
Dec 3, 2012 - 11:15 PM
Southbend makes a hybrid clutch for your needs. call Andy in the imports. tell him i sent you. you will love their clutch. www.dxdracingclutches.com i highly suggest getting a fidanza flywheel
Syaoran
Dec 3, 2012 - 11:49 PM
If you're using an S54 and have a 3S flywheel, you can use a 3S-GTE kit and bring the disc to have the hub swapped from your old disc.
Otherwise buy one pre-built like that like Smaay says. There's a couple companies that do it.
reliqhunter
Dec 4, 2012 - 2:32 AM
I heard a lot of fidanzas exploding, is it true or is it just probably intalling it wrong?
Syaoran
Dec 4, 2012 - 2:56 AM
Fidanza makes flywheels... don't think they make clutches EDIT: for the 5S/3S
Dec 4, 2012 - 2:22 PM
^^^ correct they make flywheels, and they do not explode. that is pure BS
here is a fidanza and the southbend TZ clutch next to an old OEM clutch and flywheel
95CelicaST
Dec 4, 2012 - 2:45 PM
South Bend Clutch's stage 2 kevlar clutch kit + Fidanza flywheel.
trdproven
Dec 4, 2012 - 10:15 PM
Competition Clutch + Competition Clutch Flywheel. Clutch will be hybrid, and ST185 or ST205 Lightened flywheel.
czwalga
Dec 5, 2012 - 3:43 PM
I use the exedy 3 puck... but I created a thread a long time ago using centerforces website on how to create your own hybrid clutch. So you can use any brand.
Companies like to charge extra for hybrid clutches, when really all they are doing is combining parts. If you use a company like ACT where you buy the pressure plate and clutch disc seperately, it's easy to get the clutch you're looking for.
Lil-Joe101
Dec 5, 2012 - 4:45 PM
I guess what I'm really trying try to get at is, do I buy a 3sgte flywheel n s54 clucht I.e. anything for a 94 get or what?
Dec 5, 2012 - 4:48 PM
no you are not getting it. you are installing a 3S-GTE engine so you NEED a 3S-GTE flywheel.
since you are using a 3S-GTE flywheel you NEED a 3S-GTE pressure plate.
you are using an S54 transmission so you need a 3S-GTE disk with a center hub for the S54. like i said earlier, Southbend makes this setup. Call Andy and tell him i sent you. he will take care of you. you will be VERY happy with this combination
Lil-Joe101
Dec 5, 2012 - 5:05 PM
OK smaay don't yell at me, I hate loud noises, lol. Guess I will be checkin em out after I get back from this deployment
mgnt232
Dec 5, 2012 - 7:21 PM
Im looking into doing the same thing. Now if i call andy i have no idea what your actual name is for who sent me lol. Ill prob call them tomorrow though, because I will be using the s54 trans. Now with the hybrid clutch nothing on my end needs to be done really, just install it correct?
Also the axles I will be using is it just the GT axles? thanks
Dec 6, 2012 - 11:58 AM
^^ Correct. Just install the clutch, same as any other. You would only need to use different axles if you use a different transmission, so GT axles will work.
mgnt232
Dec 6, 2012 - 12:14 PM
Just bought mine
QUOTE (richee3 @ Dec 6, 2012 - 11:58 AM)
Dec 6, 2012 - 12:43 PM
My name is Jeff Church, Andy knows me well as Smaay too.
mgnt232
Dec 6, 2012 - 1:33 PM
Yes i bought it a little while ago, he seemed pretty knowledgeable about the swap, and knew exactly what I wanted.
thanks
TRDweaponX
Dec 9, 2012 - 9:18 PM
Lil-Joe101
Mar 18, 2013 - 9:54 AM
Called Southbend today and got my clutch ordered. Thanks Smaay for the help man. I will be going with Southbend Stage 2 kevlar clutch + Act Pro Light Flywheel.
rave2n
Mar 18, 2013 - 10:03 AM
QUOTE (Lil-Joe101 @ Mar 18, 2013 - 10:54 AM)
Nice!
Sounds like you went a step above me, I only did the "HD" package.
