match220
Feb 26, 2013 - 9:55 PM
As you guys know..I built a parted out engine..now I have it semi-running (tuning it) and I put a bolt in this hole (pictured) because it leaks a ton of oil. What went here? And what is the thread? It's not 1/8 npt. I have my own sensors connected to the Autronic so I don't need a sensor there if that was what was there. Picture responses are preferred, but I'll accept a description. Thanks!
enderswift
Feb 26, 2013 - 10:46 PM
Oil pressure sensor
match220
Feb 26, 2013 - 10:52 PM
ah..ok. Where was that mounted on the 5sfe? I don't even remember seeing it when I pulled out the engine and took the sensors out.
enderswift
Feb 26, 2013 - 10:58 PM
Can't remember on the 5s. But it was most likely on the head as well. The reason I'm sure this is the oil pressure sensor is due to the fact that I had a fun time tracing a slow leak to it after searching for a source for my gauge
match220
Feb 26, 2013 - 11:15 PM
Ugh.. I hate slow leaks. I just pressure washed my trucks engine trying to find one and I still don't see it.
Malek
Feb 27, 2013 - 12:45 AM
The thread is 1/8 BSPT. It's kind of annoying. Some people have used an NPT bolt or pressure sensor without issue and others have leaks. The sensor on the 5s is on the same X plane but on the front of the block at that same corner. Pretty sure. But I'm going off memory since I pulled the engine and now it's gone haha
match220
Feb 27, 2013 - 12:57 AM
QUOTE (Malek @ Feb 26, 2013 - 7:45 PM)
I tried an old 1/8 NPT sensor that I have and it wouldn't thread in. If NPT is able to thread in it would have to start out pretty small. My 1/8 NPT sensor wouldn't even start to thread in.
Feb 27, 2013 - 12:18 PM
1/8 BSP and 1/8 NPT are very close. the oem sensor is just for the dummy light. you can re-tap it for 1/8 NPT and clean out the hole and screw in your sensor
match220
Feb 27, 2013 - 2:47 PM
QUOTE (Smaay @ Feb 27, 2013 - 7:18 AM)
So is it BSP or BSPT? BSP is straight threads and BSPT is tapered. I thought about that since I have a 1/8 NPT tap. I had to buy a tap to make a bung in my intake piping for an air temp sensor. I just don't want aluminum shavings in my engine. I would rather get a BSPT plug if that's what fits. I'm probably going to drive to the junkyard here today and get the sensor/switch that belongs there and just cut off the wires on the end.
Feb 28, 2013 - 9:40 AM
its the tapered thread. you wont get shavings in the engine if you do it carefully. like i said the threads are very very close so you can feed a 1/8 NPT in there to plug it
Malek
Feb 28, 2013 - 10:02 AM
I bought an adapter for my oil pressure sender. Auto Meter 2269 1/8" NPT to 1/8" BSPT Oil Pressure Metric Adapter
I'd link it but I'm on my phone haha
match220
Feb 28, 2013 - 4:13 PM
QUOTE (Malek @ Feb 28, 2013 - 5:02 AM)
I plugged it. I found my oil pressure sender and stuck it in there.
