Full Version: Fellow 96 Celie needs help wont start!!!
96celiest
I was cruisin down an old back road yesterday with my buddys and my car just started dien it was almost like it was running out of gas it wouldnt even budge.. nothing is wrong it still turns over just fine it just isnt getting fuel.. i tapped the one relay up by the passengers right foot that panel and it tryed to fire but then after awhile that didnt even do anything.. its gotta be something to do with the electronics. something is loose corroted or weak somewere i just neeeeed help!!!
I would check into fuses and relays first before dong anything else. Being you tapped the relay and then it tried again I'd be led to believe that's the source of your problem.
IfWeChoose
^^^yup
96celiest
ok what should i really be looking for other than just pulling fuses and relays like is there a chance that maybe a wire somewere got loose and what if i cant get to it
96celiest
could someone maybe help me out with some wiring picture diagrams and just regular part diagrams for a 96 celica st 1.8 i cant find any good part diagrams. its so hard to find stuff for my whip here in pennsylvania. everything for my car has to be ordered online here of course but does anyone know of any actual honest good toyota celica performance sites? thanks guys
southwest2118
under your hood you have a data link connector right..96?
it looks like this
(Dont ask)
just get a paper clip and jump these pins like so ...
then try to start the car...
report back..
96celiest
ok i will try that ive heard of people doing it so why not. ill get right back to you omg you guys r so ****in helpful you have no idea youve prolly saved a couple celies from the junkyards to hahahahah
96celiest
I just tryed it and it still did nothing just turned over real nice
96celiest
What should I look at first seeing how the whole paper clip ordeal did absolutely nothing
Does the CEL come on when you turn the key on?
Spider77
EFI Relay check....
It would be easiest if you did have any CEL's, since your OBDII it should be no problem (if anything pops). Besides, the relay in the right kick panel is for the heater, sooooooo. I would make sure all the fuses were good first (use a multimeter, dont visually check them). Of course you could buy a wiring diagram if its any use. Some are as low as 20 dollars on good ol ebay.
southwest2118
when you jump the pins do you hear the pump turn on? have someone put their ear on the back seat behind the driver while you jump those pins..
96celiest
well i Tryed the paper clip in the diagnostics box and it didnt do anything no CEL's just nothing but i will use that diagram for checking relays. will get back to you guys soon as possible Thanks!
southwest2118
with the paper clip in there as i stated it will bypass all relays and fuses but the EFI relay and EFI fuse..both are located in the fuse box on the drivers side under the hood.
