aiq
Nov 1, 2013 - 3:52 AM
I have a 96 Celica ST with 113000 miles. This car has been burning oil like crazy since I bought it. At least a quart every 750 miles or so. It smokes a lot when I step on gas which leads me to believe that the piston rings are shot. Is it worth it to pay someone to change the piston rings? It is due for a timing change soon anyways and I think it will be better to do both at the same time? Any ideas will be appreciated.
blackliftback
Nov 1, 2013 - 11:20 PM
I have a 97 st and it did burn a lot of oil before. I read into piston soaking with mmo. Its only around five bucks for the bottle so i went ahead anyway. For me, it worked like a charm. Not even half a quart burned between oil changes. And it use to burn at least 2-3 quarts inbetween oil changes.
I say at least try piston soaking. It may or may not work. But hey can't argue with a few bucks.
Nov 2, 2013 - 1:06 PM
Piston soak it and run with the MMO for 1,000 miles. If that doesn't do it you can always switch out to 20W-50 if you live in a warm climate and that'll slow the burn.
