valerit1
Nov 14, 2013 - 12:59 PM
Regarding the ignition switch - is it possible to remove it without pulling the steering wheel and shaft assembly?
Can it be opened to see the contacts - it is an intermittent problem, so testing by the Toyota manual will not be conclusive? Thanks!
Nov 14, 2013 - 1:46 PM
yes remove the plastics around the wheel and under the gauges and you can see the ignition stalk
valerit1
Nov 14, 2013 - 4:54 PM
Which brand should I get? Does OEM make a difference in this case?
Nov 14, 2013 - 6:20 PM
what are you looking to replace? the ignition? I suggest sticking with OEM.
