This might sound like a daft question, but I might be excused for being a novice...:
What gearbox/transmission do FWD swapped-3SGTE celicas ST use? The standard ST isn\'t strong enough, the AWD box needs the center diff welded or it won\'t work, so is there something that will work easily?
Thanks,
M.
After a little search, it seems that the proper way to do things would be to swap the 2.0 or 2.2 box in. Apparently it can take the extra power and torque.
Now, on the basis that the 3SGTE can be
made to work, does this not mean that you can (rather) easlily make a FWD or AWD celica RWD (with the propshaft and rear dif)?
I wonder if anyone has done this...
M.
yeah, s54 is certainly the cheapest option i've found around here, and although some people seem to say it cant handle it, theres a pretty long list of fairly well documentd swaps abusing the s54 for many years now with little ill effect. My research on it seems to indicate the s54 could really benefit from exchanging the 5th gear from an s51 tranny to reduce your 5th gear rpms. found it inline for about 90 bucks
Gear, 5th: 33336-33030
Ring Synchronizer, Inner no 5: 33397-333012
Ring Synchronizer, Middle no 5: 33398-12010
Ring Synchronizer, Outer no 5: 33399-33010
also cant remember whos thread it was but they included some graphs of the the rpms between the s54 and s51 with an overlay in 5th. the math to figure it out is pretty straight forward but it might be a good idea to compile all the s54 info in a thread for future reference
also the s54 can be fitted with the oem helical lsd for the 2004+ mr2 spyders, there an obx option for about 400 bucks but the reviews have been less than encouraging,
You can drive it enough to get it on a trailer. I drove mine around the back of my house with out rear axles. But i wouldnt do much more than that.
yeah since getting rid of the truck i\'ve had a million uses for it,
