QUOTE (CoolZeen @ Dec 23, 2023 - 11:20 PM)
I’m having the same problem:change the alternator, turn car on , to check , I turn the head lights on ,turn radio on and put the time on the clock, then every power inside turn off; the wipers and taillights no working nor the power look .Only thing with power is the headlights ,door lights and hazards lights. ALL fuse check good,check alternator and battery wire all normal.At least turns on but it donot have brake or signal lights
I'd suggest you check the 100amp fuse. It is on the main fusebox on driver side bay. You'd have to unscrew the box because the 100amp fuse is screwed in.
Back then, I accidentally shorted the system while changing the alternator. The car will start but not lights, no electricals.
