May 13, 2014 - 9:37 PM
or are they different.
May 13, 2014 - 9:45 PM
totally different. like 6 feet different
May 13, 2014 - 11:10 PM
Thanks. That explains a lot
yellowchinaman
May 14, 2014 - 7:20 AM
I wanted a shorter throttle cable for my GT4. Which should I go for? GT or ST?
May 14, 2014 - 7:31 AM
The st cable does not fit a beams engine. I need a gt. So st may not work with gt4 engine
May 14, 2014 - 8:17 AM
I do believe a GT or GT4 cable is required for a 3sgte motor
"Where do I start. Well, I pulled the wiring harness from inside the car out and layed across the top of the engine. I pulled the throttle cable, save it you will need it for your swap
This was referencing tearing down a ST205 clip for an AT200 swap
BonzaiCelica
Nov 28, 2016 - 9:24 PM
Why won't st cable fit onto 3sge motor?
I don't understand how Toyota made the throttle cable for st short and feed directly into firewall after it cleared the air intake pipe, but the gt had to have an excessively long cable.
There has to be a solution. Mine got semi burned by the header . I want a cleaner look. Any ideas?
Rusty
Nov 28, 2016 - 10:36 PM
Have you seen how long a GT4 throttle cable is?
BonzaiCelica
Nov 29, 2016 - 1:29 AM
Yes I have. But still doesn't my question of why st throttle cable is so shirt and gt is so long. on europe 7afe celica's they switch the cable over to feed into firewall directly like 3sge rhd setup. so why they couldn't do the same with 5sfe lhd is weird. to be continued...
Oh wait I know. The 5sfe is based of the 3sge. So since all 3sge are rhd, Toyota didn't bother engineering another plate on throttle body of 5s to save money. Am I right?
Nov 29, 2016 - 1:51 PM
plus the ST has the cruise control mounted on the right motor mount, the GT cruise control is in the front of the radiator.
BonzaiCelica
Dec 1, 2016 - 1:41 AM
Who said anything about cruise.
Well 94-96 5sfe camry have the cable going directly over intake piping like the 7afe. Got to see if interchangeable with 6gc. Or if bracjet can fit into beams with slight modification and if cable is long enough
BonzaiCelica
Dec 8, 2016 - 12:44 AM
