Guys, this is something I've been interested in doing for a while now. The s54 is a high reving tranny and that's fine for around town driving but on the highway being in 5th gear always seems like there's too many RPMs.
Solution : swap in the 5th gear set from a Camry s51 - cost, less than $200
I did a bunch of searching on the MR2 boards (and even here) and there wasn't much concrete info, just people talking about it. Some say they did it but info wasn't really clear. I then looked up some part #s and ordered a 5th gear from a Camry/Solara, got the gear and on a spare s54 at Manny's we checked out what needed to be done.
Then I found this http://www.twobrutal.co.uk/forum/showthrea...NA%29-5th-gears
That link confirmed everything I thought and he gave a great how-to, better than mine will be.
So with the Camry 5th gear set (the 5th driven gear and the 5th gear) me and Stef went to it on the s54 in the Beams.
First, this isn't simple. It's not very difficult but it's not a 10 min job either and there was one special tool needed other than normal tools we had in the garage and that was a puller for the syncro and driven gear. Stef borrowed the SST from the dealership, so we had no problems there.
We weren't going to pull the tranny for this so we did the 5th gear set swap with it in the car.
We put the car on jack stands, took off the driver's side wheel, under plastic, drained the tranny oil, and turned the wheel (hub) all the way to the left for easy access for to the end of the tranny.
took off the 12mm bolts holding the end cover on and separated it
that's what it looks like in there
First, remove the selector arm (12mm)
no selector arm
removed the span ring holding the syncros and 5th gear
with the SST (special service tool) we removed the syncros, being careful not to separate them, they can be a pain to put back together
Syncros out
Slide off the 5th gear and the 2 needle bearings (pictured)
Next is removing the driven gear. The nut has a crimp (pictured), I wedged a screwdriver in and bent it out, and the 27mm nut threads are reversed.
Used a puller to remove the 5th driven gear
Now the new gears Yeaha !
The s51 5th gear is a larger diameter than the s54 5th.
The s51 driven 5th has a smaller diameter than the s54 driven.
You can't just change one, you have to change both for everything to work.
now with no 5th gears in there, we put the Camry driven gear on using a hammer and socket, then slid the Camry 5th gear with needle bearings onto the other shaft.
This is now the hard part. Putting the syncros on without them popping out all over. We held the back of the syncros and hammered/socket it on, then pressed the 5th gear against the back of the syncro, and got it in place. The back of the syncro has 4 tabs, they fit inside 4 holes in the gear, make sure you put the syncro on with the tabs/holes lined up or you have to pull it back off and align. Re-installed snap ring.
5th driven gear, 5th gear, and syncros on
selector arm back on and ring lined up
We used FIPG sealant and Stef put the cover back on
Waited an hour for the FIPG to dry, refilled the tranny (24mm fill and drain), under plastics back on, and went for a drive.
Here's the before and after
BEFORE - s54 80mph about - 3800-3900 rpms
AFTER - s54 w/Camry 5th gear set - about 3300-3400 rpms
About a 500rpm difference from before. Shifting from 4th to 5th the rpms drop down 1000 now.
Again, my how-to isn't the best (the twobrutal link I posted at the top explains things much better than I did).
Stef will probably post a couple pics too.
Questions and comments, post em up.
keywords :s54 s51 e51 e153 Camry Solara fifth 5th gear gearset beams taller longer transmission #boompow
