yaj204
Aug 18, 2014 - 4:18 PM
Where is the ground for the pcm/ecu located?
VavAlephVav
Aug 18, 2014 - 10:25 PM
there are 4 different grounds on the ecu plugs E01 white/black, E1 brown, E02 white/black, E2 brown. which pin position varies depending on which year you have but they all go up through the wirelimb out the passenger side firewall conduit and come out and bolt to the intake manifold to a bolt between injecter 2 and 3. it's easier to see from underneath.
from what I understand there is supposed to be a braided ground strap running from one of the bolts on the manifold to the firewall.
Aug 18, 2014 - 11:39 PM
look on the back of the intake manifold. you should see the grounds bolted down there
yaj204
Aug 19, 2014 - 6:42 AM
Thanks alot... Every helpful
