gbloomer
Sep 8, 2014 - 6:51 PM
Sep 8, 2014 - 9:51 PM
swap a beams in it and call it a day. easier. faster, no rebuilding...
Sep 9, 2014 - 11:46 AM
pour oil in it and unseize it.
WD-40 and pour some in each spark plug hole. The first time leave it sit for about a week but keep adding the WD-40 every other day. After the week is over take a breaker bar and put it on the crank shaft bolt ( make sure that you turn the way you would tighten the bolt ). Never force it to much. If you can get a large hammer in to tap on the breaker bar. Once you get a little movement work it back and forth. It will eventually turn.
RavenAegis45
Sep 9, 2014 - 10:06 PM
thats a great find, I would just say get a junkyard or used engine and swap it in, generally rebuilding a seized engine isn't worth it, most likely the cylinder walls have massive amounts of scouring if they're not cracked
VavAlephVav
Sep 9, 2014 - 10:40 PM
I'd agree, even if you can get that motor unseized it no-doubt has major wear damage to the metal cylinders and bearings and ...well pretty much everything else.
a Beams would be nice, but better still is pick up a decent stock motor for it for cheap because lots of people like to take it out and swap in the performance motor, and its also the same from a Camry 2.2L. looks pretty nice and not a lot of miles, I sure wouldn't rape this one to build an ST. just so many more nice little things about the GT.
gbloomer
Sep 11, 2014 - 8:55 AM
Sep 11, 2014 - 8:12 PM
i would sell the ST, and keep the GT. but thats me, and i already did that, LOL
VavAlephVav
Sep 11, 2014 - 8:46 PM
and it has a nifty oil bottle stash since it doesn't have an ABS pump!
but you'll need to swap in a stick shift fo sho
