Can everyone do me a favor please. Im chasing down this last issue on this swap I finished. Key on, engine not running the battery light is on normally. Start the engine and It dimms quite a bit but still on.
I have looked at the Camry, 97 celica ST and GT, and several other charging wiring diagrams. they all say that pin 1 or the L signal for the light should be 0-4V with key on and engine off.
Well on this car im getting about 5.1 Volts.
I checked both my 97 Celica with the swap, and my GF 99 Celica (stock) and they both are putting out 12V on that pin.
Can you guys please go out, turn the key to ON and check the voltage of pin 1 or the L signal and post it. Im wondering if the toyota diagrams are wrong.
Pin 1 is the yellow wire and its the first one on the left looking at the plug with the clip on the top.
Thanks!!!!!!
