integra_killer
Feb 12, 2004 - 10:09 AM
I hope this is in the right topic, i think it has to do with performance...
anyway, when racing, how do you do the best launch???
do you burn the tires fgisrt so they stick better? i heard some of you guys in the auto e-brake and gas it hahaha, and for the manual guys like me, do you jsut drop the clutch? or ease it down? jsut crious on the ebst way to do a takeoff from a dead stop in our cars..
Feb 12, 2004 - 11:52 AM
unless u have slicks, its kinda pointless to burn them up before u race.
And your best launch will be when you maintain traction...popping the clutch will cause u to lose that. Just be fast but proportionate.
blkGT
Feb 12, 2004 - 4:11 PM
i rev to about 1500 drop it and slam the gas... i get no joy out of beating my car anymore tho. ive started shifting under 3k around town.
97sccelica
Feb 12, 2004 - 4:45 PM
i used to step on the brake and gas it till i hit full boost
let off the brake, the tires would spin for about 10ft(nothing bad, just a little slipage) and then once the tires grabbed i floored it.
the whole time the car would try to veer left.
oh the good times i had
RedSunCelica
Feb 12, 2004 - 6:23 PM
ive noticed just for my driving style that slipping the clutch is a bit quicker becuase i dont have to play with throttle if i have wheel spin.
NEVERSTOP
Feb 14, 2004 - 10:40 AM
if your real serious about gettin your launches down go by whats called a "launch box" it hooks up to your car and basically you preset it to idel at a certian RPM at take off - there awesome on the track.
this allows you to have consistant launches and you can practice at different rpm's and see what you like best.
SpedToe169
Feb 14, 2004 - 2:27 PM
QUOTE |
And your best launch will be when you maintain traction |
Actually, the most grip comes at about 15% longitudinal slip. So you want them to spin, but just a liittle tiny bit. Dumping the clutch and roasting them is definitely not the way to go.
snadman
Feb 16, 2004 - 2:45 AM
I can put my car in neutral and rev to 3500 rpm and drop it to low, since I have an automatic and an upgraded torque converter.
Kwanza26
Feb 16, 2004 - 3:14 AM
QUOTE (blkGT @ Feb 12, 2004 - 9:11 PM) |
i rev to about 1500 drop it and slam the gas... i get no joy out of beating my car anymore tho. ive started shifting under 3k around town. |
That'll bog me...
I launch from 3k... and go. I usually get pretty decent 60ft times, around 2.3 or 2.4 or so...
qatar11
Feb 16, 2004 - 9:00 PM
take air out of your tires, my best 0-60s where with like 20 psi in the front tires....
by the way they were sub 6 seconds :-)
OOBE
Feb 17, 2004 - 12:19 PM
Well, my auto Celi from a dead stop reached 60 in 5-6 seconds...climbs to 90 in a heartbeat at just 60 percent throttle.
I got it to 1o psi on stock squirters.
