jpodstawa
Feb 12, 2004 - 12:04 PM
Im looking to remove my Header and replace with something like a 4-2-1 or 4-1. Does anyone make them? or does anyone have a good site to buy them. Its for a 95 Celica GT, and I need them asap. Or does anyone know of a mod I can do to anouther cars Header that will work?
All information is needed.
Thanks
Jason
jpodstawa
Feb 12, 2004 - 12:24 PM
If nobody has any ideas I will need some ideas to fix a cloged Cat! I was thinking of removing the cat and putting a highflow on but its alot of work. I have the cat that hooks up right off my heads!
Jason
jpodstawa
Feb 12, 2004 - 1:11 PM
After doing some research I found out a Toyota Corolla header will fit (with some mods) is this right. If so how do I know what year I need????
Thanks
Jason
Feb 12, 2004 - 3:18 PM
If you had an ST, a modified Corolla header would fit, but since you have the 5S-FE, I believe that you need to buy a 3S-FE header and have it modified to fit. Someone else can provide a lot more info than me, because I don't know much about the 5S-FE.
jpodstawa
Feb 12, 2004 - 3:27 PM
QUOTE (Coomer @ Feb 12, 2004 - 8:18 PM) |
If you had an ST, a modified Corolla header would fit, but since you have the 5S-FE, I believe that you need to buy a 3S-FE header and have it modified to fit. Someone else can provide a lot more info than me, because I don't know much about the 5S-FE. |
But I thought that ST comes with the 7AFE?
Feb 12, 2004 - 3:35 PM
QUOTE (jpodstawa @ Feb 12, 2004 - 12:27 PM) |
QUOTE (Coomer @ Feb 12, 2004 - 8:18 PM) | If you had an ST, a modified Corolla header would fit, but since you have the 5S-FE, I believe that you need to buy a 3S-FE header and have it modified to fit. Someone else can provide a lot more info than me, because I don't know much about the 5S-FE. |
It does. You said you have a GT, which has a 5S-FE.
Celicaca
Feb 12, 2004 - 3:39 PM
QUOTE (Coomer @ Feb 12, 2004 - 8:35 PM) |
QUOTE (jpodstawa @ Feb 12, 2004 - 12:27 PM) | QUOTE (Coomer @ Feb 12, 2004 - 8:18 PM) | If you had an ST, a modified Corolla header would fit, but since you have the 5S-FE, I believe that you need to buy a 3S-FE header and have it modified to fit. Someone else can provide a lot more info than me, because I don't know much about the 5S-FE. |
EDIT: oops nvm
Feb 12, 2004 - 3:42 PM
Why do u need a header for a clogged cat?
