Full Version: OEM 3rd gen 3SGE distributor vs aftermarket trigger wheel
FunkySR
Hey all.
So I'm still in the process of getting parts together for my 3SGE turbo conversion.
Now my tuner friend has convinced me to go with an aftermarket 36-1 trigger wheel on the crank and Ford EDIS Coil pack.
Has anyone fitted an aftermarket trigger wheel on the crank?
Is there anyone here using a stock distributor on an aftermarket ECU? Please give me some pointers.
Cheers.
the only reason to use a trigger like that is for the ECU. Personally im using an AEM EMS that I made a jumper harness to work with. if the 3S-GTE and 3S-GE both have the same number of teeth in the dizzy then you can use any ECU.
