Full Version: Rear polybush problems
rhodesyboy
Hi basically I replaced all of my rear arms with powder coated ones from gt4 play fitted with polybushes and I have had some pretty sketchy moments, I like the handling in general but over certain bumps it feels like the rear is wobbling a bit and snaking around and then even more worryingly I have had the car randomly start snaking a few times on the motorway.
I have since read that you shouldn't polybush the no1 and no2 arms? Is that why I am having these issues and is it ok to keep the single trailing arm that runs parallel to the car polybushed, both on chassis side and hub side.
Had it aligned afterward?
rhodesyboy
Unfortunately no, the lobe had left a bit of an 'imprint' and lined it back up so I guess it could be off.
I was just thinking if people are saying not to polybush them so should I even bother getting the polybushed arms aligned or fit normal bushes and then get it aligned
Get it aligned correctly and then see how it is.
