Full Version: clutch options?
Zeroman
Hello!
I have a 1996 celica and the clutch is garbage due to the fact the rear main seal is leaking all over it. Going to replace the rear main seal. but figured its time for a new clutch. This is not a project race car, this is just a point A to point B car. I enjoy this car very much. 305xxx and want to keep it running. trying to see whats out there for clutch and flywheel options that wont cost me an arm and a leg but is reliable. Thanks
Tigawoods
QUOTE (Zeroman @ Feb 15, 2017 - 7:37 AM) *
Hello!
Exedy OEM Replacement or go to Toyota for an OEM Replacement
https://shop.exedyusa.com/exedy-oem/exedy-o...3/i-125840.aspx
Zeroman
QUOTE (Tigawoods @ Feb 15, 2017 - 8:25 AM) *
Hello!
Thanks! I actually work at a Toyota dealership. but was checking out my options. I will be installing a factory Toyota rear main seal.
Southbend.
x2 Exedy o.e. replacement. Except for that's the wrong clutch above, it's for a GT and not the ST. This is the one you want: https://shop.exedyusa.com/exedy-oem/exedy-o...8/i-125896.aspx
Tigawoods
I didnt go as far as to check his profile lol. I figured he could do the rest of the leg work
jordisonjr
x3 on Exedy OEM replacement
the ST uses the exact same clutch as the 2ZZ in the 7th gen. just food for thought
