I bought my Celica in 2009, and decided to turn it into a Drift car in December 2016 after spending the last year going everywhere sideways in a v8 Nissan Stagea
First issue was the front subframe being smack in the way, so I had to notch it out and box it back in
Next thing that needed sorting was the gap to the firewall, sorted by cutting a massive hole, and planning to fill back in with new firewall further back
I decided I'd swap the super strut front end for a MacPherson strut off an st202 I'm breaking, so had to adapt the hubs of the st202 for the St205 front brakes to fit
I spent a whole weekend making engine mounts and welding them together and to the chassis, only to figure out later on that they wouldn't work very well for packaging reasons so Chopped them off and threw them in the bin, then came up with the crossbar under the front of the sump (don't worry there's a 7mm gap) and being solid mounted to the chassis
This weekend I've managed to get the steering rack mounted
And also managed to cut the tunnel out where needed to test fit the is200 gearbox to the 1uzfe mock up engine
The propshaft has also been cut to length with the is200 front spline and U/J ready to be welded up once I've felttled the joint a bit, no pictures unfortunately
Future plans are fuel cell in the rear, finish up the turbo manifolds, custom wiring harness for the entire car, tube frame front end and general Drift tweaks.
