Full Version: Trouble Shifting right to left (manual)
I'm trying to fix this now, but just wondering if anyones had a similar problem? it will shift into gears just fine, but when I'm trying to shift right to left it doesn't want to move. anyone have a similar problem? last year i changed the clutch, flywheel, pressure plate, shifter bushings, base bushings and everything has been working fine since.
There was corrosion around the shifter bushing causing it to not shift easily right and left. sanded off the corrosion and problem solved
