Full Version: 95 Celica 1.8
Celica96863
I have a 1995 Toyota Celica 1.8 liter, it shakes only one warm. Till this day not one kind of can figure the problem out. I have changed plugs wires cap and rotor, to O2 sensor in coolant temperature sensor. Till this day no idea what is wrong with her. Can someone help? Does anybody have any experience with Celica? This will be very very helpful thank you
How are your electrical grounds? Motor mounts?
cheela
x2 on motor mounts and grounds too.
I know mine are in serious need of changing but it doesn't shake too much.
Mounts. If your distributor is adjustable check that the timing is set right. Adding a ground didn't help with my idle EXCEPT when the radiator fan came on it helped take away that dip in idle.
