T3naci0usT
May 15, 2017 - 3:29 PM
I was wondering if you could help me out guys. I got the car to idle properly, but it still is dumping gas in the car. Would you guys suggest bad fuel injectors, or would it maybe be a fuel pressure regulator? I can't get the a code reader to work either, is this OB1 or OB2. Thank you for the help
May 15, 2017 - 6:51 PM
Without knowing anything about the car we can't give you any help.
May 15, 2017 - 7:45 PM
I think it was a '98-99 GT yes? In either case it'll be OBD-II. Dumping fuel can be leaking injectors and/or too high pressure due to faulty regulator, it can also be a faulty coolant temperature sensor for the ECU or an O2 sensor making the car run rich. The injectors or FPR wouldn't throw a code(could get a cylinder misfire code though technically), and the ECT or O2 can malfunction and not throw a code if they're still in spec even though what's being sent is wrong.
T3naci0usT
May 17, 2017 - 1:46 PM
So it idles good, it just doesn't feel like it has any power, and if I give it more than a quarter throttle it feels like it loses power. I also can't get the OB2 port to read codes, but I may have a blown fuse for that. Thank you for your help.
T3naci0usT
May 19, 2017 - 2:01 PM
I think it may be the Catalytic converter. A lot of the symptoms are applicable. Especially the engine performance and running rich.
What do you guys think?
T3naci0usT
Jun 1, 2017 - 8:15 PM
So, I was wondering. I still can't get the OB2 port to work on the car.... I replaced the fuse what else can I try?
DST94
Jun 2, 2017 - 10:00 AM
Why don't you remove the cat? That would be an easy way to test if it's turkey the cat
Jun 2, 2017 - 1:37 PM
It could be your scanner, I've seen where certain scanners and cars don't get along even though they're both technically OBD-II there are different types of protocol. As to the other there's many reasons increasing throttle could bog it besides the catalytic converters, but it's usually easy enough to drop one and inspect it as well as seeing how the engine runs without it.
T3naci0usT
Jun 5, 2017 - 11:47 AM
So these are the two things im thinking about doing for the car.
I am thinking about taking off the cat, and if that doesn't work then I think the engine is low on compression, and I am going to replace the head.
