QUOTE (Smaay @ May 24, 2017 - 10:31 PM)
use a test light, the big wire that is bolted to the starter is constant battery power. the black plug is key switched power. pull out the plug and stick the test light into it. turn the key to start and see if the test light comes on. if it does then you are getting proper power to the starter. if it does not, then you have an electrical issue. check relays and fuses
Thank you! I did. It happened to be something very stupid and minor but frustrating.
