Full Version: Which Suspension/Handling Upgrades First?
GuYun14
Hello,
I'm planning on doing some upgrades to my car's suspension and handling and just wanted to know which upgrades I should start with.
Here's a list on what I want to do:
-Coilovers
-Strut Bars
-Sway Bars
-Polyurethane Bushings
-And maybe end links
And if you guys have any other more suggestion, more upgrade is appreciated. Thanks!
Tigawoods
that will get you far. beyond that there really isnt too much more you can do
the one thing you missed is the most important. tires.
RE71R's or similar compound tires will do so much for the car
jordisonjr
If you're changing your spring and strut to coilovers, or even lowering springs and a new strut, you'll likely need to change end links anyways. Most times you have to cut them off the stock set up, so I'd plan to change them, rather than a maybe.
Either than that you've got a pretty good list there.
HectortheRican
Like the others said, can't really think of anything else (other than underbody bracing) that would give you much of a boost. That's a pretty comprehensive list.
And like tiga said, TIRES!! If I were forced to choose a single handling upgrade, it would be a good set of tires. You'll see the biggest single improvement there.
GuYun14
Thanks for all the advice and suggestions. So in which order would you all recommend I start with? I'm guessing good tires would be first?
Tigawoods
tires
sway bars
strut braces
coilovers
poly bushes
narly_charley
Like said before... TIRES!
Set 8 minutes aside and watch this:
https://www.youtube.com/watch?v=S2S6MJt0998&t=197s
GuYun14
QUOTE (narly_charley @ Jun 12, 2017 - 5:04 PM) *
Lol I actually watched a lot of Engineering Explained when I first started looking at mods. Also, I feel that if I was to get good tires then I would want a nice set of new wheels as well.
I'd say tires/rims, coil-overs, sways, poly bushings, then strut braces last. Though if your bushings are worn out and need replaced I'd move those on up to right behind tires/rims.
jordisonjr
QUOTE (Box @ Jun 12, 2017 - 7:15 PM) *
I agree with this.
bloodMoney
I honestly can't stand the Engineering Explained guy. Just saying.
GuYun14
QUOTE (bloodMoney @ Jun 13, 2017 - 2:41 PM) *
I think he does a good job explaining how things work but it's too much math for me lol
And thanks guys! I'm currently running TC wheels on 215/45/17 tires and since good tires seem to be the top choice, I might use the TC wheels as my winter wheels and buy nicer wheels. Or I can start with what I can afford first lol
cheela
throw some brake pads and rotors in there somewhere too.
a car's gotta stop sometime...
GuYun14
QUOTE (cheela @ Jun 13, 2017 - 1:57 PM) *
Just recently put on some new OEM replacement rotors and brake pads but what I really need is new calipers.
The tC rims are nice quality being an o.e. piece, just on the heavy side compared to some other options out there. Being you live up north for tires I'd look into the BFGoodrich COMP-2 A/S or Cooper Zeon RS3-G1 or RS3-A for a performance all season that won't cost an arm and leg, they're not necessarily cheap but they're not the most expensive ones out there either.
tr1stan
Had the same dilemma before and I ended up getting new lowering springs and struts. I went with Tein springs and bilstein shocks. A bit stiff yet ride is still comfy.
Wild202
What do you want to achieve from the car?
A lot depends on this answer.
GuYun14
Decided to go with Eibach lowering springs and KYB struts and car definitely handles better. But the reason is that sometimes I like to go to the backroads and drive my heart out so there's that. But if I can, I might wanna to take my car to the track.
BonzaiCelica
Upgrade to superstrut... Well nvm you already bought stuff
