Full Version: 99 Celica GT
Well I have a 99 GT. It's leaking oil pretty bad somewhere behind the block on the timing belt side. I actually just replaced my timing belt and it didn't look like oil was coming from the oil pump or the crank seal. I also leak power steering fluid just as fast as I can put it in, but I'm sure that's the power steering pump. Anyone have any ideas on my oil leak? Between the power steering leak and oil leak, my engine is a mess and so is my cv shaft and everything else on that side. I'd post pics but I'm at work.
I also did my timing belt recently and went ahead and replaced the crank shaft seal, oil pump seal and the cam shaft seal also
Some seals don't leak when the car is turned off mostly happens when the car starts and runs due to pressure . Give that a check .
