PERFORMANCE
2nd gen 3sgte swap ('91 mr2 turbo) - block: hot tanked, honed, replaced freeze plugs, decked & painted
CP pistons, Eagle Rods, ACL bearings, ARP studs, rod bolts & flywheel bolts
Rebuilt head, hot tanked, decked, new valve seals, cometic gaskets throughout, new valve cover & bolts
NGK spark plugs, Magnacore wires, new timing belt, tensioner & pulleys, new high power 160amp alternator.
new oil pump, Walbro fuel pump, water pump, & fuel filter assembly's & koyo radiator w/TRD t-stat.
poly-filled gt4 motor & tranny mounts.
LSD, just replaced trans fluid with Redline MT-90
fidanza lightened flywheel, f1 stage 2 clutch, new throwout bearing & redline fluid
3" downpipe (no cat), front mount Mishimoto intercooler, 3" straight intake to K&N air filter
JDM mr2 ECU
EGR deleted
cold start injector deleted & replaced with Intake Temp sensor in preparation for stand alone ECU
Enkei RSV bronze 17x7 w/ Hankook Ventus HRII h405 215/45/17 tires
rear disc conversion including, stainless steel brake lines, drilled & slotted rotors, new rear wheel bearings
Front Lexus ES300 2 piston Calipers, GT Rotors & Stainless Steel lines
Suspension
D2 Coilovers
Suspension Technique Sway-bars
Megan front strut bar
GT4 rear strut bar
Exterior
moonroof shade
clear side markers
completely stripped & repainted/clear coated black engine bay to match engine
hood struts
stripped and resprayed underside in rubberized black
6000k HID's in lows
Interior
6.5" component alpine type-r's (front) and6.5" alpine type-s (rear)
7th gen black perforated leather GTS seats
7th gen 3spoke steering wheel
Sabelt 2" 4pt race harnesses (not completely installed)
pure white cluster LED conversion
Vincents black-black leather accessories (arm rest, shift boot and e-brake)
"custom cup holders" relocated to inside console
clear (Tundra) courtesy door lens covers
battery relocated to trunk
And now I give you.... evilRed95
I just so happen to be a member of Team Mishi, so bonus that it has the Mishimoto FMIC
Looks like it belongs here...
I need to give it a good bath and a nice shine, it's got some nice goodies.
Time for my Premium Sound Door Cards to be installed
Finally have a use for my complete leather interior, it's been waiting for the right car.
Some cleaning, and such and this is going to be incredible.
