i am not sure on how to submit how to articles so i just did this i hope thats alright
Philips head screwdriver
Ratchet with philips head bit or short philips head screwdriver
Small flathead screwdriver
First of all, you have to remove your gauge cluster there are instructions under the how-to for Changing Gauge Cluster Light Colors. The goal here is too get your center section of your cluster out, it is held in with 4 Philips head screws from the back of the cluster. Once you get the center dial out you can see the back of it there is a little metal tab that you need to remove just use your little flathead screwdriver to pop it off you will then clearly see a little rod with star wheels on it there will be one for each digit of your odometer you need to pry up on the end of the rod so that your digits are free to spin on your gauge face. Next set your numbers to where you want them make sure that when you put the rod and little wheels back in place so that the digits on the gauge face aren’t able to move or else your odometer won’t read properly it may take some trial and error to get it right but it is important that you do get it right. Put your metal clip back on and reinstall your new gauges with your actual odometer reading. my Gauge started
![](https://i.imgur.com/HvqsD1f.jpg)
![](https://i.imgur.com/2e4H0k0.jpg)
![](https://i.imgur.com/btmLBzV.jpg)
