Full Version: ST205 steering column
Project6g
Hello guys, I have a UKDM ST205 that had a broken ignition switch, in the process to replace it the previous owner, he made a mess so the ignition switch does not align with the plastic housing and the steering does not lock when it is in the off/lock posetion. I also have in my position a complete steering column from an st202 JDM, are these just plug and play? I know there is different placement of the wipers with the indicators, but my main concern the wiring is compatible?
Thank you in advance. All the best!
slavie
Are you keeping it RHD? Steering columns should be compatible, but some electrical components (airbag and turn signal) may be different depending on the years of the car, column, and the steering wheel you intend to use (pre-facelift vs post-facelift). All the electrical connectors are easy to swap though. Easiest way: there is a plastic box that sits b/w the column and steering wheel which houses the clockspring and turn/wiper stocks - keep that, the steering wheel, and the harness as a set if anything is different.
For the ignition switch, if you need to keep the key, set it to acc (if I remember correctly), and depress the small pin on the side of the switch column, and the switch with the key pulls out. If you need to remove the ignition switch column, it's possible but you have to deal with 2 security bolts (notch with cutoff wheel, use manual hammer driven impact screw remover - worked for me).
Project6g
QUOTE (slavie @ Nov 1, 2017 - 9:00 AM) *
Thanks mate for all the info. I am staying RHD so I will replace the column as a set. The car is postface and the donor car is also postface so I don't think to be any issue. I hope when I plug everything to work correctly and I hope I dont have to repin eny connectors ( UKDM has the indicators left vs the JDM that has the right)
