Full Version: 1994 celica want spin over
jim
So I got in my car to leave and I pushed the clutch in and hit the switch and it turned over a few times and stopped .But it still has power . Where do I go
from here ?
Battery could be weak, check it with a voltmeter.
jim
QUOTE (Box @ Nov 9, 2017 - 11:09 PM) *
Thanks I checked the bat. it's like a safety switch or something because it was spinning and then stopped
jim
any one know how to check the safety switch on the clutch on my 1994 celica
You can pull the connector off the switch and jumper it with a piece of wire.
jim
that was not it I bypassed the clutch switch
also it keeps popping the am2 fuse
You have a short in the ignition system somewhere then if it keeps blowing the AM2 fuse.
jim
ok guys that was it my resistor is bad. So I changed it started it up and the coil went bad ? this is the fourth coil in three years ant one know why they would go bad so often
Have you ever replaced the ignition coil cable? A bad cable can cause too much strain on the coil and burn it out.
