Full Version: 6 speed transmission
So has anyone tinkered with the 6 speed tranny from a TC. or is it a 5 speed seems like it bolts to a2gr, same way it should to a e153.
Be interesting to see what can be done to use it.
BonzaiCelica
2nd gen scion with EB60.
i thought Aurion came with a manual 6 speed, but its a 6 speed sequential automatic...
what are you trying to accomplish. I know its not mpg, you want shorter gearing???
http://www.mr2oc.com/188-v6-mr2-forum/3811...r-soon-yup.html
no, i want newer transmission. because unfortunately the e153 is old, and stupid expensive to repair.
slavie
Bolting up will be hurdle #1. Is there a clutch that will work with a 2GR and/or 3S flywheel and that box? Driveshafts? Mounts? Shifter linkage could probably be worked out easily though.
An E153 out of a Gen1 Solara can't be that expensive.
And do you mind educating me on what newer features the E153 is missing? I thought it was a well rounded box, especially the later ones with multi synchros and all.
http://www.mr2oc.com/188-v6-mr2-forum/4244...nformation.html
That's what you wanted to see?
QUOTE (slavie @ Dec 5, 2017 - 9:02 PM) *
well the 153 missing a 6th speed.
its not about that, its about research and options, e153s are hard to get. a solara will work, but they are not common either.
newer transmissions mean newer parts.
mostly preference. newer engine, newer transmission. If i had never tried to slam the 2gr in my car, i would have never known it fits. So someone has to try... But not right now, need to finish projects. but will continue to research.
clutch, yes... axles yes....
some one did it...
hes running a 6 speed, on a celica. but getting info from him is kinda hard. even in his own facebook group. lol
BonzaiCelica
oh sick
some guy in panama with a 6th gen and 3sge beams with dual vvt-i is in the process of fitting a 7th gen celica GT-S 6 speed. he was quoted $600 for a custom flywheel
that doesnt even include the bell housing plate that is also custom which i assume is another $500....
Odd choice fitting a C series on a S engine but OK. From what I can gather the TC/Camry 6spd bolts onto the S series engines and uses the MR2 pressure plate/clutch? I thought that's what it said in the thread I linked but maybe I was reading wrong. I suppose he wants the C60 for it's gearing though which makes sense with a 3SGE.
ILoveMySilly97
I know this doesn't help much but I ran into a post where a guy had an white AW mr2 chassis with a 2grfe mated to a 6spd manual trans. IIRC it was from a newer camry or newer TC. He stays somewhere along the coast of California.
