QUOTE (Keiri @ Jun 8, 2010 - 5:25 PM)
That's what my RS3000 equipped '99 has. To double-check/verify check under the seat for a black or gray box with a single wire cluster running into it that's held in place on one side with a zip-tie. That, if there is one in your car, is the control/programming box for the system and you'll need the fob, a paper clip, and about 5 minutes to program it.
The fob you need can be purchased from eBay for between $25 and 50 dollars. You want the oval shaped fob (gray or black - I have one of each and both work) with two buttons and information on the back as such:
FCC ID: BAB237131-022
CANADA 2024101526
MADE IN JAPAN
Just search for "Toyota fob BAB237131-022" and you should find exactly what you need.
That’s for a ‘99, but I believe I just sent cheela a ‘99 remote that wouldn’t work with his ‘97. He could share more accurate info on that.
