Full Version: TOYOTA 90910-13004 TOYOTA CANISTER PURGE VACUUM CONTROL SOLENOID
brandon702bmx
On the left side of my engine block facing from the outside on the intake manifold, there is a solenoid mounted there. I searched for it on Google and I cant figure out whether or not it's the genuine part my car. It's called a TOYOTA CANISTER PURGE VACUUM CONTROL SOLENOID VSV part number 90910-13004. I'm looking for a replacement VSV and all of them that I look up look way different from the one I have. Basically what I'm asking is if it's the genuine part for my car and if the ones I've been searching are the correct ones.
This is the part that I had:
TOYOTA CANISTER CONTROL SOLENOID VSV
This is the part I found that is supposed to replace it?:
REPLACE EGR VACUUM SOLENOID
I've been trying to troubleshoot the reason why my car has had poor idle and has terrible acceleration and I can't find out why. I'm desperate at this point. I've swapped another engine in and have had the same issues.
ST204GT83
The one on the intake manifold is the Vacuum switching valve, it's not the same. Why do you think the purge vsv is the issue?
brandon702bmx
QUOTE (ST204GT83 @ Apr 5, 2018 - 2:29 AM) *
That piece was mounted to my intake manifold on he left side if you're looking at the car. It's broke. One of the nipples have broke off. I just want all the EGR components squared away because it's gotta be some cause of why I'm having rough idle/poor acceleration.
I have 2 friend where their cars don't even have this piece at all. However, they have a 96 and 97. Where my canister control solenoid has a hose running to it on the intake manifold, there's is blocked off with a stud or bolt of some sort. I'm sure me being OBD 1/older definitely has something to do with it.
