Full Version: GT four front brake conversion question
95chameleonGT
What size hub centric ring do you have to use to center the brake rotors on the stock hubs? I'm using brz rotors and I tried doing the measurements myself but the first set I ordered didn't fit.
Tigawoods
You'd need to collect get the rotors bore size and the hubs bore size measurements. Be aware that the hub may have a chamfer at the base of the bore circle making it slightly larger than the listed bore size.
Measure again and get a couple more made
