Full Version: FS: 1997 Celica GT Convertible 3sgte swapped - SOLD
6G Celicas Forums > 6th Generation Celica > Buying/Selling
HardHead93
$6000, will entertain serious offers
1997 Celica GT. It has the following:
143K miles on Chassis
Gen 4 3sgte swap, swapped approx 12k miles ago
Stage 2 BC Cams
ATS Sweet 16 Turbo
Upgraded Billet 12psi internal Wastegate
BC Coilovers
Kirkosaurus Front/Rear Mount inserts
5sfe ACT Clutch
3sgte Exedy Pressure Plate
Lightweight Flywheel
ARP Head Studs
Adjustable Cam Gears
MS3PRO EVO Stand-alone ECU
Electronic boost controller run by ECU
Conversion wiring done by WireGap
850cc injectors
Walpro 255 fuel pump
Flex Fuel Tune
Dakota Digital SGI-5E for speedometer
Koyo Radiator
Polyurethane Bushings
Front Mount Air to Air Intercooler
2.5 inch intercooler piping
Replica HKS Blow Off Valve
Air to air oil cooler
Custom 2.5 inch exhaust
2 piston Avalon front calipers
Drilled and Slotted Rotors
Vented VIS Carbon Fiber Hood
TRD Front Splitter
TRD Side Skirts
LED Low beam headlights and fog lights
17x8 wheels wrapped with 225/45r17 tires
300hp on 91 Octane/340hp on e85, https://www.youtube.com/watch?v=hoYzDhaDjEM&t=216s
Ralco RZ Short Shifter
Solid shifter cable bushings
Solid shifter base bushings
Glowshift Oil pressure gauge
Oil/Water Temp Gauge
Innovative Boost/AFR Gauge
3 pod pillar for gauges
Pioneer touch screen radio
6.5 inch pioneer speakers all around
GT Covers front seat covers
Aftermarket Keyless entry
All my spare parts come with the car too (OEM gauge cluster, OEM Fans, spare transmission, etc)
I have it posted on Facebook marketplace at: https://www.facebook.com/marketplace/item/346996852866097/
HardHead93
bump
