Full Version: WTB: Group Buy for Narrow E Series Transaxle
6G Celicas Forums > 6th Generation Celica > Buying/Selling
BonzaiCelica
biggrin.gif biggrin.gif Group buy for Narrow E Series gearbox conversion parts. The S54-06D transaxle that came on beams engines is nearly difficult to rebuild, as internal parts are hard to come by. However there is a solution for those who wish to keep their celicas for a few more decades. Upgrade to the Rav4 E352F/Scion TC E350 internal gears with 96-2000 Rav4 E250 transaxle casing. A combo of 2 different transaxles is needed for better gearing (not optimal)
The shifter cables you need are 94-97 7afe or the 94-99 3sgte, The gearbox mounts and transaxle brackets are the same between E56 equipped ST202 celica and ST205 Celica with some minor differences.
Finding all these parts were difficult and took me nearly a year and half to accumulate. The axles are the hardest to find. 3D scanning will be needed to replicate the exact design (similar to what MR2 Heaven has been doing)
E56 Gearbox Mounts by Justin Towers, on Flickr
E56 Gearbox brackets by Justin Towers, on Flickr
E56 CV Axles by Justin Towers, on Flickr
BonzaiCelica
this is where i bough my axles. i believe he still has one set left. email him to be sure. he responds quickly.
http://www.gt4-racing.eu/produkt/celica-t2...nt-axle-shafts/
BonzaiCelica
here is the video explaining all the details
https://youtu.be/kb3F5238fco
BonzaiCelica
1st and 2nd drive gears are casted to input shaft. Pinion Gear is cast to output shaft.
Use Mass Damper from E35# onto E250 transaxle casing
E56,E154F and E250 share same speed sensor
E154F transaxle Speedo Drive Gear (33403-29495) only in Japan
E56/E153 (SW20L) transaxle speed drive gear (33481-12100)
E350 transaxle speed drive gear (33481-28050)
ST205 Celica 215/50R16 (24.46in)
Celica 205/55R15 (23.88in)
Scion TC 215/45R17 (24.7in)
Custom Set up 235/40R17 (24.4in). This is widest tire you can run
3.538 ratio outputs max speed of 34pmh
3.214 ratio outputs max speed of 37mph (less torque to wheels and prevents wheel slippage)
3.070 ratio outputs max speed of 39mph
BonzaiCelica
update. turns out the sw20 axle carrier bracket will work. found a rav4 at the yard and pulled the bracket off, looked at part # and it was from an sw20 turbo mr2. these are available new from primemr2. toyota lists diff part # because it comes with a stud from factory that has 2 stabilizer bars attached to it. despite the pass axle E153 having a different bearing part number vs rav4/celica, i confirmed that it fits my E56 axle.
BonzaiCelica
bump
BonzaiCelica
for comparison. These are all with transaxle's filled with fluid
Rav4/Celica E56/E250 weighs (3.7 qts fluid capacity)
Celica/Corolla C60 weighs 91.7 lbs (2.4 qts fluid)
2001 Rav4/TC E350/E352 weighs 102 lbs (2.6 qts fluid)
2016 Scion/Corolla IM weighs 97.4 lbs (2.5 qts fluid
2011 Scion TC EB60 weighs 107.2 lbs (2.4 qts fluid)
