> 404 Kit Probs, Will this fit?
post Mar 1, 2004 - 6:45 PM
hermo69
Joined Dec 7, '03
From CANADA
Hey guys,
I know i can count on 6GC for this one. I have a 94 Celi and I bought a kit online. Now I read that 94 - 95 needs 404 kit and the 96+ uses 404a. If I got the 404a, is it possible to "make" it fit on my car? I guess what im trying to say is how are these two body types different?
Thanks
post Mar 1, 2004 - 6:49 PM
Here is the '94 and '95 front end:
And here is the '96+ front end:
As you can see, the two are quite different. You're much better off just buying the front lip that fits your car, or upgrading to the '96+ front end(which bolts right on) and then installing the 404a lip. wink.gif
post Mar 1, 2004 - 7:15 PM
RedSunCelica
From San Diego CA
well technically the only difference is the turn signals. you can still buy a 95 front bumper and bolt up fine to a 99 but hte turn signals wont work. i think the reason erbuni made differnet kits was because of the turn signal issue. but ill tell you for sure when i buy it and test it out. biggrin.gif
post Mar 1, 2004 - 7:24 PM
The turn signals are different, but remember, the 404 or 404a lip is just that, only a lip that adds on to the bottom of the bumper. wink.gif
Also, the front bumpers are more different than just having different turn signals. If you look at that very bottom edge, you can see how on the newer bumpers, it bulges out where the posts come down. On the '94 and '95 bumpers, it's smooth in that area.
Also, you can see from the photos above that the number of posts, and post arrangement is very different. wink.gif
Also, chaning turn signals is incredibly easy. Two screws and twisting in a new harness connector on each side is all that's required to do this. wink.gif
post Mar 1, 2004 - 10:37 PM
Cragspider
Joined Aug 30, '02
From Franklin,Tn
Well, It will take a lot of work to make the 404a lip to fit on a 94-95 front. Just sell the lip and get the right lip for the car.
Bryan
post Mar 2, 2004 - 3:47 PM
hermo69
Joined Dec 7, '03
From CANADA
So techinically i could still use the skirts and the rear lip and then just put on a different front bumper?
post Mar 2, 2004 - 4:14 PM
QUOTE (hermo69 @ Mar 2, 2004 - 12:47 PM)
Maybe. Is your car a hatchback? The rear bumpers and lips of body kits are designed only to fit the hatchback Celicas, and not the coupes or convertibles.
post Mar 2, 2004 - 4:48 PM
macavely
Joined Nov 4, '02
i thought the reason why the 404 didn't fit the 94-5 celic what cause of the 5 posts on the front? if thats true why not just cut off the 5 post since they aern't used for support
post Mar 2, 2004 - 4:54 PM
oOoHuY
Joined Nov 12, '03
From h town
my question is can i make the 96-99 front bumper fit on a 94-95??? that what i wanted to know because i love the 94-99 front bumper
post Mar 2, 2004 - 4:55 PM
QUOTE (macavely @ Mar 2, 2004 - 1:48 PM)
Well, the very bottom horizontal piece of the bumper is different as well. Notice in the pictures above how it bulges out on the '96+ front bumpers, and how it doesn't on the '94 and '95 bumpers. wink.gif
Also, yes, you can buy a '96-'99 front bumper and turn signals, and put it on your '94 or '95 Celica. A couple members have done this before. Everything bolts right up.
post Mar 5, 2004 - 12:54 AM
oOoHuY
Joined Nov 12, '03
From h town
will a 96-99 front fit a 94-95 celica? if it possible what do i have to do and buy thanks
post Mar 5, 2004 - 7:57 AM
QUOTE (oOoHuY @ Mar 4, 2004 - 9:54 PM)
As said above, yes, it will fit just fine. You'll need the bumper and the turn signals, and then you just take off the old bumper, put on the new one, and then switch the turn signals. smile.gif
Lo-Fi Version Time is now: September 4th, 2026 - 1:53 PM
