Apr 2, 2004 - 11:51 AM
does anyone know how much shorter the TRD short shifter is then the stock?
This post has been edited by macavely: Apr 2, 2004 - 11:52 AM -------------------- |
Apr 2, 2004 - 11:54 AM
Enthusiast ![]() Joined Mar 12, '04 From Norway Currently Offline Reputation: 0 (0%) |
About 6 ....
j/k ... I have no idea |
Apr 2, 2004 - 11:55 AM
frome the pics i seen looks like 1.5 inche. does anyone know
Apr 2, 2004 - 1:26 PM
i though its like 40-50% although i do no have one... I was kinda thinking that you might as wel save your 160-180 bucks.. or shifters are not bad at all, compared to some of my friends cars... also they can screw up your sinq... an its a lot of freaking money.
Apr 2, 2004 - 1:38 PM
Enthusiast ![]() ![]() ![]() Joined Dec 2, '02 From Portland, Oregon Currently Offline Reputation: 0 (0%) |
Short throw reduces the shift length by 40-50%, it is not a 40-50% decrease in shifter length. I don't have one either (YET!) but I think you're pretty close Mac.
This post has been edited by Doge: Apr 2, 2004 - 1:39 PM |
Apr 2, 2004 - 2:00 PM
actaully mac, theyre not even that much shorter i think. i have the trd quickshifter, is not made to be a "shorter" shifter, its made to shorten the throw between shifts, and does so QUITE well..
Apr 2, 2004 - 2:02 PM
so do you think if i cut a stock shifter buy an inch ... it would be close.. i just want to make sure be 4 i cut it..
Apr 2, 2004 - 2:18 PM
it will make the shifter shorter, yes...but its not the same..its more of the angle of the trd shifter that affects the throw
Apr 2, 2004 - 3:13 PM
first i wouldnt sugest it, my buddy did it to his car an it srcewed a few things up, although he does not have a celi. And Its not the angle, im sure what you even talking about, its a shorter distance in the rod,points were there onnecting, there for it engaes to each gear with less movement and force... |
Apr 2, 2004 - 3:28 PM
if you compare the two, they are vituallly the same length.
they are ANGELED diffrently which shortens the throw between shifts. the bottom half of the shifter rod has more angle to it. thats what i am talking about. -------------------- Former Team 5SFTE pro member ;)
Apr 2, 2004 - 8:34 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 25, '04 From Wisconsin Currently Offline Reputation: 0 (0%) |
thanks pressure. That actually cleared up alot of things. I didn't think a "short shifter" was just shorter but my friends insisted. My buddy shortened his talon's shifter by cutting and it was sh!t afterward. I could hardly put it into 5th without using the palm of my hand. But the TRD angled short shifter sounds like the way to go.
Apr 2, 2004 - 8:53 PM
no problem man..not that im an expert or anything, actually quite the opposite
but it gives you the idea of how it works... -------------------- Former Team 5SFTE pro member ;)
Apr 2, 2004 - 9:00 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Oct 22, '03 Currently Offline Reputation: 0 (0%) |
Some people cut the oem shifter in three places. They move the piece with the pivot point to a higher position.
[=o=][==][=O <----the first piece is the one with the pivot. The last is the shifter. [==][=o=][=O <-----they weld it back with the pivot at a higher location. I know it sucks but its the basic idea. EDIT: Atleast that was what i was told. This post has been edited by LatinKraze: Apr 2, 2004 - 9:02 PM |
Apr 2, 2004 - 9:53 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
isn't there some sort of how to on main page.
-------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
Apr 4, 2004 - 11:25 AM
Enthusiast Joined Mar 23, '03 From Fort Worth, TX Currently Offline Reputation: 0 (0%) |
Most short shifters actually increase the effort it takes to shift. That's a common by-product of reworking the angles of the shifter. The factory designed it to reduce effort (hence the factory knob being so heavy). To shorten the throw, you would have to increase effort. My short throw shifter is from TWM, and was cheaper than the TRD unit. Still works great after two years, too. This post has been edited by black-st: Apr 4, 2004 - 11:29 AM |
Apr 4, 2004 - 10:38 PM
were did you get the TWM shifter from? -------------------- |
| Lo-Fi Version | Time is now: August 21st, 2026 - 5:19 AM |
