Apr 12, 2004 - 10:30 PM
Enthusiast ![]() Joined Apr 3, '03 From Omaha, Ne Currently Offline Reputation: 0 (0%) |
Alright I had a thought. Most people complain a ton about the cost of the JDM 3s swaps. What if instead of importing a 3s to the U.S. you pulled the motor out of a 5th gen all-track. I would assume it would bolt right up, right? Would the wirring also be easier since your swaping from a left hand drive to a left hand drive? If all this were true, I think that it would be cheaper, granted you would only have about 200hp compaired to the might JDM 3s's
I havn't ever seen this discussed on here, and always wondered about it. Sorry if this has already been discused buy I couldn't find it, and didn't see anything searching for it. |
Apr 12, 2004 - 11:41 PM
Enthusiast ![]() ![]() ![]() Joined Sep 22, '03 Currently Offline Reputation: 0 (0%) |
Its been discussed here. But USDM 3SGTE's are usually pretty beat up and JDM engines can be easily found with lower mileage.
Apr 13, 2004 - 1:26 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
the harness would not have to be extended but other than that, its the same engine
alltracs are rare, let alone a wrecked one you could pull the engine from it would cost more than to get a JDM engine, which bolts in the same, and have Qatar do your wiring the only other benifit is that the engine would be a US engine and pass visual smog checks, but the clerks are too dumb to spot a JDM engine anyway -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Apr 13, 2004 - 10:47 AM
the harness doesnt necessarily need to be extended on the JDM version either.
Apr 13, 2004 - 11:49 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 15, '03 From San Jose, CA, USA Currently Offline Reputation: 1 (100%) |
why would you post with no explanation....? you propose making an additional hole in the drivers side of the firewall and mounting the ECU on the drivers side? or did you mean something else? |
| Lo-Fi Version | Time is now: August 9th, 2026 - 9:25 AM |
