Apr 23, 2004 - 5:00 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
i get this rattling sound (like when u roll your tongue, seriously exactly like that)....but only when i let go of the gas pedal quickly. it starts right when i close the throttle, and lasts about 1 second. i thought it was the intake or intercooler pipes rattling whenever air gets stuck BUT thats what the bov is for, and its still working. AND i secured the intake so that it doesnt move and checked the pipes, i still cant find the source of the rattling.
TO TOP IT OFF everytime i accelerate faster than normal with boost gauge going to 5 psi, when i stop, i get this HUGE cloud of white smoke coming out of the exhaust. it clouds up around every car around me. ALSO, if im accelerating quickly for more than one shift, i see white smoke come from the sides of my hood as well as the exhaust!!! Im pretty sure its coming from the turbo burning oil cuz the exhaust runs directly off of that, but how do i fix it?? I'm scared of driving bc if its damaged i dont want to worsen it. also im still getting high knocking indicated on my safc2. it starts off at 0 during cold start, then gets to 30 and stays there. heeeeeeeeeeeeeeeelp! This post has been edited by forkee: Apr 23, 2004 - 5:25 PM -------------------- ![]() |
Apr 23, 2004 - 5:07 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Maryland Currently Offline Reputation: 8 (100%) |
The sound sounds like your BOV is to loose or tight. Shuttering.
-------------------- Member of Team 5sfTe
Apr 24, 2004 - 12:45 AM
I would say it sounds like your blowing your rings, i dont know a ton about turbos, but i know enough that most stock engines dont run great, or even good for long with them. but then again, white smoke out of your exhaust norm means blown head gasket, .... I would take off the head, and replace it, i would guess a kit would be around 50-100 bucks..
Apr 24, 2004 - 1:19 AM
but how come it only happens after the turbo spools hard??
Apr 24, 2004 - 2:41 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
most likely its a problem inside the turbo -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Apr 24, 2004 - 11:57 AM
Enthusiast ![]() ![]() ![]() Joined Aug 31, '02 From KC Currently Offline Reputation: 0 (0%) |
Are you losing any coolant? could be a head gasket leaking under the extra pressure from boost, does the smoke smell like oil or anti-freeze? |
Apr 24, 2004 - 12:27 PM
yea i just drove to disney and back (30 miles) while keeping it on the VAC side of the boost gauge. It ran fine. No smoke.
Apr 24, 2004 - 2:12 PM
Enthusiast ![]() ![]() Joined May 8, '03 From San Jose, CA Currently Offline Reputation: 0 (0%) |
sounds like a blown turbo oil seal. The same exact thing is happening to me right now. Only when you're on the turbo hard, or boost fast, etc. If you keep it in vac it's fine. Time to rebuild the turbo, perhaps. - aba |
| Lo-Fi Version | Time is now: August 11th, 2026 - 11:18 PM |
