> wheel hop
post Apr 28, 2004 - 10:35 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
Is it just me or do these cars get an obscene amount of wheel hop.
if i launch and get the tires spinning the car hops. i find it very hard to race because of this. every single time i spin the tires the car hops like a mofo.
what could be the problem and how do i fix it?
post Apr 28, 2004 - 10:39 PM
94Toy
Joined Apr 3, '03
From Omaha, Ne
If you are racing, and getting that much tire spin then you must be revving really high. I never get wheel hop. Mabey you should check your tires. Could be over inflated.
post Apr 29, 2004 - 10:23 PM
XXX_Mina
Joined Jan 8, '03
From Miami, FL
get a 3sgte and then complain of wheel hop... my **** does it like crazy, even without launching.... bad springs or shock absorbers i suppose... just upgrade your suspension and you should be fine
Mina
post Apr 30, 2004 - 9:38 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
QUOTE (94Toy @ Apr 29, 2004 - 3:39 AM)
not revving high at all
rev it to 1200 and get wheel hop
post May 1, 2004 - 12:07 AM
spunky393
Joined Apr 22, '04
From illinois
You're revving it to low, hahahaha.
I used to have the same experience with my 95. Personally, with good tires, i got a great start with 4500, i'm sure i could've fine tuned myself a little bit more, but i never got the chance....dang guy ran me into a median.
The most important lesson I learned from Karate-Dō Kyōshan“You can not be what you do not believe you are”
post May 1, 2004 - 9:45 AM
Your suspsension sucks...get a better suspension.
post May 4, 2004 - 12:10 AM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
QUOTE (spunky393 @ May 1, 2004 - 5:07 AM)
serious? rev to low?
post May 4, 2004 - 3:58 PM
spunky393
Joined Apr 22, '04
From illinois
That's what i think, everyonce in a while, i don't mean to get a race start (like at a stop light all by my self), and i really wanted to just go forward, haha. So that means my rpm's were around 2500 or so, and i get wheel hop. What are your rpms when you get your wheel hop?
post May 7, 2004 - 11:08 PM
wind
Joined Nov 4, '03
From Vancouver, Canada!
i can take off at around 3000 and i get no wheel hop.... get better tires and suspension
post May 9, 2004 - 7:47 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
QUOTE (spunky393 @ May 4, 2004 - 8:58 PM)
hops at about 1200 and above
post May 9, 2004 - 10:43 PM
spunky393
Joined Apr 22, '04
From illinois
try a 3500 start.
post May 9, 2004 - 10:44 PM
spunky393
Joined Apr 22, '04
From illinois
and also, tell me exactly what you do, like after you dump the clutch, do you slam the gas down, and stuff like that.
post May 10, 2004 - 9:59 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
QUOTE (spunky393 @ May 10, 2004 - 3:44 AM)
yes and no
ive tried both putting it down and not puttin it down.
oh and when its raining, no wheel hop. foound that out the fun way
post May 11, 2004 - 8:09 AM
spunky393
Joined Apr 22, '04
From illinois
Well, the rain is common smartz, haha. Less friction. I would say hyping your rpm's up some more when you get off the line, that should get rid of the low rpm wheel hop, if you're putting more power to the wheels at once, then it also creates less friction, and then of course cetchs, you're at a high rpm, and you're off!!
post May 11, 2004 - 8:18 AM
SpedToe169
From Dallas, Tx
What physics class did you take? That doesn't make any sense at all.
post May 11, 2004 - 11:13 PM
spunky393
Joined Apr 22, '04
From illinois
i didn't read it after i wrote it, sorry, haha. I should've said, if you put more power to the wheels at once, and create spin, the friction is lost. But, it will come back, and that's your start. Does that make more sence. I think i might be confusing my self, but i'm sure he gets the idea
post May 12, 2004 - 8:39 PM
red_94gts
Joined Feb 15, '04
From saskatoon, sk
yeah i got the idea. i tried launching at 3000 and the tires spun but no wheel hop. the only thing is its quicker not launching because i get too much spin
post May 12, 2004 - 8:46 PM
spunky393
Joined Apr 22, '04
From illinois
just kinda play with the launches and how much gas you put in after you launch
post May 12, 2004 - 8:48 PM
spunky393
Joined Apr 22, '04
From illinois
i also forgot to tell you, if you're racing, or just want to play around even more, let a little air out of your front tires.
post May 12, 2004 - 9:56 PM
let air out of your tires = step one
rev up to around 2000 rpm with the clutch out far enough that its grabbing and you let out anymore your goin to move= step two
light turns green dump the clutch hit the gas you might even do this at a lil lower maybe not sure yet = step 3
Lo-Fi Version Time is now: September 2nd, 2026 - 3:31 AM
