> Trunk won't bolt, Key will no longer turn to the left
post May 5, 2004 - 5:07 PM
shid
Joined Jan 8, '04
From LA
Hey all, I have a coupe vert and about a week ago my trunk just stopped bolting. I'm in the habit of bolting the trunk every single time I open or close it- because in a vert you can just reach in and open the trunk if the tops down- alarm doesn't matter.
But now, it won't even turn to the left! So suddenly. I don't know what gives. It will turn to the right and pop the trunk just fine- but will no longer bolt.
Does anyone know how to fix this? or at least how to expose the unlocking and bolting mechanism? If I could see it, maybe I could figure out whats wrong. Please be detailed- I'm a little weary about unscrewing things in my car.
--Sean
post May 6, 2004 - 7:29 AM
blkGT
Joined Jun 10, '03
From FL
QUOTE (shid @ May 5, 2004 - 3:07 PM)
--Sean
open your trunk and look at the inside of the rear. theres a peice of plastic, now theres some circular peices of plastic about 1.5 inches wide. pop them out. there should be like 6 of them, and then you can just pull that peice of black plastic out. now you can see the inside of your tail-lights and the complete locking mechanism of the trunk, and the cables that work it.
post May 6, 2004 - 11:21 AM
shid
Joined Jan 8, '04
From LA
Thanks! I'll check it out this weekend and get back to here..
Lo-Fi Version Time is now: August 26th, 2026 - 6:23 AM
