May 9, 2004 - 9:48 AM
Enthusiast ![]() ![]() ![]() Joined Apr 4, '04 From New York Currently Offline Reputation: 0 (0%) |
whats the best tool to useto cut little holes in it. im new to fiberglass and dont want to break it. and can you copy fiberhglass. exmple like can i make an exact copy of this peice if so how ? thank
This post has been edited by gtcelica94: May 9, 2004 - 9:49 AM |
May 9, 2004 - 9:53 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 3, '02 From Va Team 6gc Currently Offline Reputation: 1 (100%) |
i use my Dremel and it seems to work realy good.
to make a copy u need to make a mold but i don't know how so i wont turn u in the wrong direction. -------------------- ![]() All I have in this world is my Balls and my Word and I'm not breaking em for no one,- Tony Montana Team 6gc 2005 |
May 9, 2004 - 5:33 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 8, '04 From KY Currently Offline Reputation: 0 (0%) |
To make circular holes use a hole saw, you can get it any hardware store. It is a drill bit with a circular saw on it and you just drill slowly and it cuts a hole.
For like squares and stuff use a dremel tool with reinforced cutting wheel. |
May 9, 2004 - 6:11 PM
Enthusiast ![]() ![]() Joined Sep 18, '03 From Dirty Jersey Currently Offline Reputation: 0 (0%) |
i used a dremel with either the cutting wheel or the sanding barrel... both worked great. i did the primary cutting with the wheel and cleaned it up with the barrel.
May 9, 2004 - 6:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
drill bits work just fine for small stuff
as for the molds.. there are tons of differnt ways to do it.. if you had a pic of the item you wanna copy it would be easier to tell you which way to use -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
May 9, 2004 - 6:37 PM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
To make a mold you can take the piece and spray mono insulating foam all over and then pull it off. line the mold with alluminum foil and then start fibreglassing. Do a search on fiberglass basics. Someone please confirm this is a good way.
May 9, 2004 - 7:09 PM
i can use drill bits i heard i couldnt, im just trying to drill out the little holes to go into my splitters, so im guessing a dremel.
mono insulating foam will this mess up my peices, will it pop tight out or will it stick to it |
May 9, 2004 - 11:37 PM
Enthusiast Joined Dec 23, '03 Currently Offline Reputation: 0 (0%) |
there is a few different ways to make a mold... like said before you could use the insulating foam or just line the piece that u want to copy with either masking tape or duck tape.. apply the first layer of fiberglass and then pull it off and work from there... the tape comes off fairly easy... with masking tape u may not be able to get it all off
chris |
May 9, 2004 - 11:45 PM
first cover your piece with aluminum foil and then do the foam. it will slide right out when your done.
May 9, 2004 - 11:48 PM
ok i think i got it now . one last question where can i get that foam or whats the name of it
May 11, 2004 - 12:46 PM
just go to home hardware or home depot or wherever Americans go for their home building needs. It insulating foam in a can. MONO makes one and i'm not sure of other brands.
| Lo-Fi Version | Time is now: July 30th, 2026 - 4:02 PM |
