May 18, 2004 - 11:30 PM
Enthusiast ![]() Joined Aug 19, '03 From KY Currently Offline Reputation: 0 (0%) |
Okay, I hooked up my apexi safc, and did it just like the how-to for the SAFC II (except ofcourse for the extra wires). When I start the engine it will run for a minute and then die. I was wondering what may be the cause of this. I should say that it dies when the wire that is attatched to the yellow and white wires is cut. When I reconnect that wire, it runs perfectly normal. Can anyone help? Please.
May 19, 2004 - 7:09 PM
Okay, does anyone with a 7a-fe have an Apexi SAFC, and if so, how did you hook it up, and what did you set your car setting and gauge type as?
May 19, 2004 - 7:16 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 13, '02 From So Cal Currently Offline Reputation: 3 (100%) |
ask 97sccelica....he put mine in
May 19, 2004 - 9:06 PM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
mine works fine, u may have to adjust some of the settings upon start up, ex, sensor type, and pressure type will make a huge difference.
May 19, 2004 - 9:12 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 29, '02 From ny to philly Currently Offline Reputation: 0 (0%) |
I just followed the directions in the how-to. was relatively straightforward besides having a sore back trying to reach the wires down there.
| Lo-Fi Version | Time is now: August 26th, 2026 - 10:51 AM |
