> Battery Light, I changed battery now its on, ????
post May 24, 2004 - 11:03 AM
kmad86
Joined Aug 30, '02
From Fort Smith Arkansas
I changed my battery and now my light is on, do i need to reset something?
post May 24, 2004 - 11:41 AM
Pali_playa
Joined Apr 4, '04
From VA, USA
reset ur ECU
post May 24, 2004 - 12:36 PM
Junior
Joined May 5, '03
From Toronto
altenator could be gone
post May 24, 2004 - 1:51 PM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
Did you charge the battery?
post May 24, 2004 - 3:27 PM
kmad86
Joined Aug 30, '02
QUOTE (Pali_playa @ May 24, 2004 - 9:41 AM)
reset ur ECU
How do I reset the ECU
post May 24, 2004 - 6:58 PM
Rjb23
Joined Feb 8, '04
From KY
Make sure your battery cables are tight, and make sure you have good contact at your alternator.
post May 24, 2004 - 8:49 PM
S_C_M
Joined Mar 2, '04
From Louisiana, USA
QUOTE (kmad86 @ May 24, 2004 - 8:27 PM)
If you had the cables off of the battery for more than a few seconds while you were swapping batteries; the ECU is reset. No need to do it again, a bad alternator or connections are more than likely your problem.
post May 26, 2004 - 11:07 AM
ZoomZoom
Joined Apr 7, '04
From Toronto
your problem is the alternator.
you have to change it w/ new or used.
Lo-Fi Version Time is now: August 2nd, 2026 - 2:52 PM
