Jun 8, 2004 - 12:08 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 26, '03 From Wisconsin Currently Offline Reputation: 0 (0%) |
After reading johns install thing I still have a couple of questions to the DIY'ers
The top nut on the front since it has very little pressure is that going to be a problem to put back on? Common sense question but not POSITIVE: the rubber ends on the springs go to the top right? im like 95% positive they do. In the Tein thing they recommend getting a new lock nut? wtf is this and do I need it? Do i need alignment? I've heard yes and no. With the money I save I can pay to get it done. Shops in the area wanted ****ing 400 bucks. This post has been edited by Andason: Jun 8, 2004 - 12:09 PM -------------------- i am awesome
Jun 8, 2004 - 1:24 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 30, '03 From O-town, FL Currently Offline Reputation: 0 (0%) |
take pics
Jun 8, 2004 - 1:32 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 9, '03 From Dayton, OH Currently Offline Reputation: 2 (100%) |
well...after you install them see how the car feels alignment wise...if its pulling funny then i would get it done. Also look at your wheels on the side of the car and see if they are tilted in (negative camber) if you see noticable negative camber then your tires will start to wear on the insides. I drove for about a year with like -2 degrees in the rear..it wore the insides of my tires down pretty bad.
It should be fine to use the original lock nut up top. If you get new struts they will come with one but the original will be fine if you dont remove it too many times and wear it out . You talking about the rubber tubbing around the springs to keep noise down? Yeah its probably best to put the closer together coils up...it really doesnt matter though This post has been edited by bufferdan: Jun 8, 2004 - 1:34 PM -------------------- ![]() |
Jun 8, 2004 - 1:41 PM
also, alignments should cost NO MORE than 70$ for a all-wheel alignment. Check tire-discounters or bigOtires if you have them. Dont tell them your car is lowered or they want to charge more for some reason...just say "not that i know of" if they ask
Jun 8, 2004 - 1:53 PM
oh that top bolt which is under pressure is no biggy it pops off and goes on easy you DON'T need a compressor
Jun 8, 2004 - 1:58 PM
so the rubber end goes up?
Jun 8, 2004 - 2:08 PM
im not quite sure what you mean by rubber end? teins come with rubbing tubbing around the springs right?
It will work either way but i have heard there is less noise with the tighter coils at the top because they dont hit together as much. Tein puts the rubber around them though to stop noise when they hit together. -------------------- ![]() |
Jun 8, 2004 - 2:16 PM
![]() Moderator ![]() ![]() ![]() ![]() ![]() Joined Apr 17, '03 From Rockland NY Currently Offline Reputation: 15 (100%) |
yes, the rubber end goes up. you can use the old lock nut, I used it. I do see a need to get an alignment right away. Its an easy install, if you dont use a spring compresor the becareful taking out the top nut cause the stock spring is under pressure. Dont forget to cut the rubber stumps on the shock shaft.
It will take you about 4 hours to do. good luck DEF -------------------- ![]() I will return one day. |
Jun 8, 2004 - 2:34 PM
now go put them things on!! Dont take off the top lock nut with the spring faceing your face either
Jun 8, 2004 - 2:36 PM
... waiting till 5 to use a friends shop.
Jun 8, 2004 - 2:39 PM
take off the top nut while the strut is still bolted on the car
Jun 8, 2004 - 3:00 PM
good plan...i did my rears with them off but the rears arent under any pressure. I had spring compressors just in case but i didnt get to use them. On my 3000GT i had to use the spring compressors though..someone woulda been hurt if i didnt -------------------- ![]() |
Jun 8, 2004 - 5:28 PM
Enthusiast ![]() ![]() ![]() Joined Sep 29, '02 From Sterling Heights, Michigan Currently Offline Reputation: 0 (0%) |
I have pics of my S-Tech and KYB install if anyone needs pics.
Jun 8, 2004 - 10:39 PM
easy but time consuming install... im sitting low
Jun 9, 2004 - 7:34 AM
Get some pics up when you get a chance.
Jun 9, 2004 - 9:14 AM
![]() Enthusiast ![]() ![]() Joined Sep 6, '03 From Fairbanks AK Currently Offline Reputation: 0 (0%) |
yeah that top nut is under a bit of pressure had a bruise on my chest for a while. last time i had an alignment i took it to sears and since it didn't need any adjustment they didn't charge me anything. although you will probably need adjusting.
side note how much camber adjustment do we have without haveing to get the adjustment plates? anyone know...just curious |
| Lo-Fi Version | Time is now: August 11th, 2026 - 7:10 PM |
