> EGR??
post Aug 9, 2004 - 3:14 AM
macavely
Joined Nov 4, '02
just wanted to know how has or has thought about removing it? and for those that have, did you notice and incressed performence?
post Aug 10, 2004 - 12:31 PM
Snarfer
Joined Dec 2, '03
From Virginia
I don't think the egr will hurt out car too much, I just read this in a toyota spec sheet.
"The ECM considers the EGR system and an integral part of the entire engine control system. Therefor the ECM is capable of neutralizing the negative performance aspects of the EGR by programming additional spark advance and decreased fuel injection duration during periods of high EGR flow. By integration fuel and spark control with the EGR metering system, engine performance and feul economy can actually be enhanced when the EGR system is functioning as designed."
So I guess unless ur running a stand alone its not gonna do much for your car. and could cause problems if the ecm expects the combustion gas to be cooler then they should, and it'll probably give you a check engine light.
This post has been edited by Snarfer: Aug 10, 2004 - 12:42 PM
post Aug 10, 2004 - 12:32 PM
There are EGR "block off plates" or something similar available. You might wanna look to the MR2 guys for more info.
Doing it though might not be worth the time and money, the gains will be minimal.
This post has been edited by Supersprynt: Aug 10, 2004 - 12:42 PM
post Aug 10, 2004 - 12:39 PM
bufferdan
Joined Nov 9, '03
From Dayton, OH
Its very easy to bypass EGR just by disconnecting the vacuum hoses and pluging them. I did it on my camaro when i had it. I havent messed with it on the celica though. Its illegal and you probably wont pass emissions if you have that.
post Aug 11, 2004 - 12:44 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
the egr valve is closed on WOT so you wont notice a difference when you get on it. and yeah e-bay has some egr black off valves for like 16 bucks.
Former: 96 GT 5 speed (i/p/e) Fate- rear ended by mack truck
00 GTS 6 speed (i/ Bored TB 63mm - 68.5mm w/ butterfly/ Ported IM/ IMG/ PFC/ Commander/ datalogit/ Ported & heat wrapped Header/ Decat/ UEGO/) 193FWHP 14.2(1/4mi) @98mph, 2.12 60ft (just intake, unbolted Exhaust, and gutted) Fate- side swipped by 18 wheeler at 75mph.
Next: maybe an elise
post Aug 11, 2004 - 1:12 AM
maikl
Joined Mar 3, '03
From cyprus
what is egr?
post Aug 11, 2004 - 1:14 AM
recneps
Joined Jul 7, '04
From charlotte N.C.
it filter exaust gases back into your intake manifold to reduse emissions. but on the downside your getting hot dirty air to be conbusted.
post Aug 11, 2004 - 1:21 AM
Snarfer
Joined Dec 2, '03
From Virginia
post Aug 11, 2004 - 1:28 AM
maikl
Joined Mar 3, '03
From cyprus
ohhhhhhhhhhhhhhhhhhhhhhhhhhhhh. yes i know what are you talking about! this is the first time i am hearing about removing it!
post Aug 11, 2004 - 1:33 AM
macavely
Joined Nov 4, '02
well i'm thinking about geting a stand alone.. for when i do my little turbo project... so i really don't want got gasses sucked back into the intake.... the EGR is just one of them many things i have thought about... so many thought so little time ... pass the advil please.
post Aug 11, 2004 - 11:42 PM
celicaboston1983
Joined Mar 20, '04
my friend took out his egr b4 and it ****ed up his engine. The engine light would stayon and it made his car choke when he drives for the first 30 mins
post Aug 11, 2004 - 11:55 PM
recneps
Joined Jul 7, '04
From charlotte N.C.
yeah someone on here said there egr valve got cloged and they burnt trough gas like crap and he car would shake a lot
Lo-Fi Version Time is now: August 31st, 2026 - 7:34 PM
