Aug 14, 2004 - 8:28 PM
Enthusiast ![]() Joined Feb 3, '03 From Pensacola Florida Currently Offline Reputation: 0 (0%) |
anyone know what the "hub" part is called, that you have to take the cotter pin out of and put a 20 mm socket on , that entire piece that the brake calipers go on and bolts to the strut? also the cv axle goes into it. the bearings in mine were trashed in a wreck and i need that assembly with the bearings in it (drivers side front) but i need to figure out what it is called before i can order one :D
so far ive thought of, hub assembly? |
Aug 14, 2004 - 8:47 PM
thats what it is a hub assembly pretty much
if you need the bearings just look up "wheel bearing" i can find you a part number in a bit from advanced auto parts *edit* http://www.partsamerica.com/SelectParts.as...earing%2C+Front that is the link for the part its called a pinion bearing This post has been edited by playr158: Aug 14, 2004 - 8:49 PM |
Aug 14, 2004 - 8:52 PM
that the steering knuckel ... i know i had to replace it 2 times..and you have to order every part by its self... if you buy every part new
steering knuckel wheel hub seals rings caliper bearing This post has been edited by macavely: Aug 14, 2004 - 8:55 PM -------------------- |
Aug 14, 2004 - 8:56 PM
what noise does it make, or vibration or what not......cause my passenger side is making a wierd noise and i can feel it kinda bump like i had a rock in the tire but its not that
Aug 15, 2004 - 2:42 PM
it made a noise like the tires were much wider than they are (225/40/17), and looking at the car the camber was way out of wack, that one wheel was pointing inwards and riding on the inside corner of the wheel (ruined a new tire). thanks for the info.
-dave |
| Lo-Fi Version | Time is now: August 31st, 2026 - 3:20 AM |
