> how or what to use to cover hole on trunk, cover hole on trunk
post Aug 18, 2004 - 12:07 AM
VietCelicaGt
Joined Aug 13, '03
my friend just got some wing put on his car and im wonderin how can it be cover..usein what...i heard of bondo but i was wonderin if anybody know anything else easier .....any help be thankful....thanks b4 head of time
post Aug 18, 2004 - 7:09 AM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Cover what hole? If you took off the stock spoiler there should be three on both sides and one (or two) in the middle. Closing it off right involves welding the holes shut with a mig welder, using body filler, and repainting that area of the car.
This post has been edited by flipside97LTD: Aug 18, 2004 - 7:10 AM
post Aug 18, 2004 - 10:27 AM
gtcelica94
Joined Apr 4, '04
go buy some metal tape, use a peice to cover the whole area, push the tape in the hole after you layed it flat over the hole. get some fberglass.dyna-glass or what evers, sand 80 grit, put some body filler over it, sand 80 grit, then some spot putty sand down with 220 grit, call it a day
post Aug 18, 2004 - 10:58 AM
VietCelicaGt
Joined Aug 13, '03
now where do i get alll of these stuff from..pepboys?
post Aug 18, 2004 - 10:59 AM
VietCelicaGt
Joined Aug 13, '03
can u guys giv me the name of the product soo i can get it...thanks
post Aug 18, 2004 - 2:48 PM
gtcelica94
Joined Apr 4, '04
you can get the tape from pepboys, look in the phone book for body shop supplies and ask them if they carry body fillers and fiberglass filers. Evercoat is a good name.
filler site
this is a good site to buy stuf from , i get my supplies from them
post Aug 18, 2004 - 7:22 PM
VietCelicaGt
Joined Aug 13, '03
kool just wat i needed...thanks a bunch
post Aug 18, 2004 - 10:25 PM
x_itchy_b_x
Joined Nov 12, '02
From Webster Ma.
post Aug 18, 2004 - 10:52 PM
fastgt
Joined Feb 13, '03
From California
gum might work????....haha im no help
id say (if you were me) take it to a body shop
2011 Spice Orange Mini Cooper
2011 Alpine White BMW E92 M3
gone but not forgotten
2008 Space Grey BMW Z4 ///M
post Aug 19, 2004 - 7:04 AM
ShadowFX
Joined Jan 22, '04
From WA, Australia
if you took it to a body shop, how much would you be looking at? and also if using the method/s above, is it very noticable that there were holes there in the first place?
post Aug 19, 2004 - 9:44 AM
VietCelicaGt
Joined Aug 13, '03
i call around and even driv to some bodyshop..some told me 200 and some rols 250...i only have 6 holes to fill in...why so much ....im usein tape rite now to cover the holes up....after removin the stock spoiler..yea the was holes already..haha biggrin.gif
This post has been edited by VietCelicaGt: Aug 19, 2004 - 9:47 AM
post Aug 19, 2004 - 4:57 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Well I just finished welding up my holes. I took off the stock spoiler and am putting on the hiro wing. The holes that didn't match, I welded up and it looks great. I still have to paint the car but you can't see the holes anymore. This is most likely what a bodyshop is going to do.
post Aug 19, 2004 - 5:08 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
To do that: use a surface grinder and grind to bare metal all around the holes you'll be welding (about an inch or so from the hole). Now grind to the bare metal somewhere else in an unnoticable place, this is where you'll connect the charge clamp from the welder. Now weld the holes shut. When you've got them welded up, use the surface grinder to grind the weld down flush with the car. The heat from the welding is going to cause the metal around the welds to heat up and it's going to sink down a little. That why you need to use body filler. Fill over the welds and smooth out the sinkage until it looks like original. Then repaint it.
post Aug 19, 2004 - 5:14 PM
gtcelica94
Joined Apr 4, '04
that looks good, how easy is it to weld.
i found a pic if you still want to do it the fiberglass way
post Aug 19, 2004 - 5:20 PM
VietCelicaGt
Joined Aug 13, '03
omg that a big hole....but goood pic ...it be a goood guide...i will use the pic to guide me to cover or fill the hole biggrin.gif
post Aug 19, 2004 - 5:24 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Well it seems both ways will work. How durable is that tape? The only problem I see is that if that tape sunk in, the filler wouldn't be strong enough to hold the shape.
post Aug 19, 2004 - 5:43 PM
gtcelica94
Joined Apr 4, '04
the tape is only there to make a mold. look at 8, its fiberglass,9 is the filler over the glass.
post Aug 19, 2004 - 5:57 PM
hwo about just finding some type of rubbler stopper to put in there. if you do it the same color as your car, it wont look that bad, and you can reinstall the wing, if you choose to go back to that look later.
post Aug 19, 2004 - 6:27 PM
flipside97LTD
Joined Nov 29, '03
From Hampton, VA
Well it depends dude, see if he's gonna be putting in a new wing, rubber stoppers might get in the way. I guess it just depends. Beautiful car by the way lagos. biggrin.gif
This post has been edited by flipside97LTD: Aug 19, 2004 - 6:28 PM
Lo-Fi Version Time is now: August 4th, 2026 - 9:40 AM
