Sep 15, 2004 - 11:54 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Sep 6, '04 From oakdale Mn Currently Offline Reputation: 0 (0%) |
allright i have the yellow top fuel injectros from a 1989 7mge engine i went to go see if the clips matched up and they did not. what do i have to do here. these should work right
thanks This post has been edited by rjbibeau: Sep 15, 2004 - 11:54 PM -------------------- ![]() |
Sep 15, 2004 - 11:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Nov 4, '02 From Davenport Iowa Currently Offline Reputation: 0 (0%) |
You need the greentops.. there actually kind of a light yellowish green
here is a link to another thread of mine.. in there is a link to a site that has all kind of info for toyota injectors.. it will show you the difference between the yellow and lime green ones greentop flow rate thread -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Sep 16, 2004 - 12:05 AM
and what kind of car can they be found on?
these are the same ones i have are these the ones injectors This post has been edited by rjbibeau: Sep 16, 2004 - 12:10 AM -------------------- ![]() |
Sep 16, 2004 - 11:51 AM
bad link there... here are the type and part number you want
![]() there off the MKIII non turbo supra.. 87.5 - 92 I believe, they came with the yellow tops or the Green tops.. the blacks are for the Turbo version This post has been edited by NEVERSTOP: Sep 16, 2004 - 11:52 AM -------------------- ![]() 99 project version 3.0.. hello SEMA 2010 =) |
Sep 16, 2004 - 3:21 PM
those look like the ones i have i'll go check the part number. but on mine the clip does not clip into the 5sfe injector harness
Sep 16, 2004 - 3:43 PM
allright those aren't what i have. my part number on my injectors are 23250-20040 but when i bought them they said they were from a na 89 supra with a 7mge engine this has got be stumped
| Lo-Fi Version | Time is now: August 29th, 2026 - 4:31 PM |
