> 3sfe 98 2.0 16v ????, who has these spec?
post Sep 18, 2004 - 6:02 AM
xonethug
Joined Sep 13, '04
From U.A.E dubai
does any one else have these specs ???
i noticed that everyone has 1.8 's 2.2 's and turbos ..
but i live in dubai U.A.E and i have a 1998 2.0 3sfe m/t 82000 kms ....
and want to know if there is a Preformance ECU chip that i can get for it ...
and what are the possibilitys to turbo it ?
what are the 0-100 top speeds of all the 6g celicas?
i have hit 215 kmph on mine -- my profile pic show 209 ..
This post has been edited by xonethug: Sep 18, 2004 - 6:03 AM
post Sep 18, 2004 - 9:35 AM
BEEFSTEW800
Joined Dec 30, '03
From Atlanta
this is all i could find:
3s-fe:
hp- 138@6000RPM
torque- 138ft-lbs@4400RPM
im not sure, but i would guess that the 3sgte turbo manifold would bolt on to it so you probably could turbo and run low boost without too much modification.
post Sep 18, 2004 - 12:30 PM
saleeka
Joined Sep 4, '03
From Twin Cities MN
QUOTE (BEEFSTEW800 @ Sep 18, 2004 - 2:35 PM)
im not too sure about that... the 3SFE has a completely different shaped combustion chamber than the 3SGE and GTE if im not mistaken, so I dont think its quite that simple...
post Sep 18, 2004 - 3:27 PM
Anub1s
Joined Nov 27, '03
The 3sfe has a completely different head than the 3sge or gte. You could run the boost and the manifold might work but I would go for a head swap and some internal build up before I even thought about boosting.
post Sep 19, 2004 - 12:47 AM
FallenHero
Joined Dec 26, '02
From Alabama
Basically it's a 5sfe with lower displacement. Same head set up. and less size. In other words, it's a boat anchor just like the 4afe as compared to the 4age. in thought: 4afe, 7afe, 4age is to 3sfe, 5sfe, 3sge.
Lo-Fi Version Time is now: August 27th, 2026 - 12:13 AM
