> gaskets and seals, for oil leakage
post Oct 15, 2004 - 2:50 AM
gnetik
Joined Aug 14, '04
My car is leaking oil somewhere and i can't pinpoint it. I replaced the valve cover gasket, but that's about it. What other gaskets/seals can contribute to oil leakage? confused.gif
post Oct 16, 2004 - 9:54 PM
Snarfer
Joined Dec 2, '03
From Virginia
where is the oil accumulating?
post Oct 16, 2004 - 10:18 PM
gnetik
Joined Aug 14, '04
QUOTE (Snarfer @ Oct 17, 2004 - 2:54 AM)
IT accumulates around the passenger side and drips down from the engine block around somewhere above the oil pan.
post Oct 17, 2004 - 11:17 AM
97GTinKC
From KC
Clean the engine off, easy-off oven cleaner can be used according to Popular Mechanics magazine, its cheaper than regular engine cleaner, (but I wouldn't get it on any painted surfaces either) clean it, hose it off, let dry, then use an aerosol spray foot powder, should be able to see the source of the leak in the powder (I suspect they havn't looked under the hood of a Celica- pretty tight in there)
(taken from tips in this month's Popular Mechanics)
From personal experience, it will be the highest and farthest forward point that is wet with oil, in your case, if it is above the oil pan, you have the valve cover, PCV valve/hose, camshaft seals, or head gasket, probably in that order of likelyhood ...
post Oct 19, 2004 - 12:51 AM
gnetik
Joined Aug 14, '04
So i just spray away with the foot powder at any place i think it's leaking? Foot spray?! hehee kinda funny!
post Oct 19, 2004 - 1:05 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
could it be power steering fluid?
post Oct 19, 2004 - 9:58 AM
FallenHero
Joined Dec 26, '02
From Alabama
Lo-Fi Version Time is now: May 24th, 2026 - 2:00 PM
